No SIM card then back to LTE
ChrissyChay
My phone keeps saying SOS no SIM card and then goes back to LTE ? Why is it doing this ? It’s not the first time it’s done it either !
HI @ChrissyChay
if you have service now, it is ok
but if this happen again, something wrong with the sim card or the sim tray.  From my experience, usually is the sim tray rather than the sim card.
if that happen again, you can test the sim card  in another phone or test another sim card on this phone.   At least you should remove the sim card , clean it and firmly put it back in.
Darren21
As a very first step I would double check rjat it's not a hardware issue. You can simply do a restart and then check your network settings quickly. If that doesn't work follow the info Handy 1 has posted for support. Make sure the sim and tray are clean and seated properly. I had to uninstall and reinstall my sim on another phone and restart and it solved my problem.
@ChrissyChay  Are you services working ? If not and it keeps saying SOS this could be sign of incomplete account set up and support can help to fix
submit ticket with support using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agent
