No Points program
12-03-2022 02:30 PM - last edited on 12-04-2022 10:56 AM by Leon987
12-03-2022 03:09 PM - edited 02-17-2023 08:35 AM
Hi @2299 no problem. If you want ticket to agent, please send them here ( again , there is no real reason to opt out of the new rewards, you cannot get to the old system by opt out)
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
12-03-2022 03:07 PM
- Thanks. I made a mistake and I thought I was just sending a message to an agent. That’s why I had my account number on the message
12-03-2022 02:49 PM
If you joined PM after 2022 Jan. then you have points and no way to go to $ rewards. If that is so, you have to wait to collect 15 points you can convert to $ to pay bill, purchase add-ons, etc.
12-03-2022 02:47 PM - edited 12-03-2022 02:50 PM
12-03-2022 02:33 PM - edited 12-03-2022 02:34 PM
@2299 hi first remove your personal account info,you are on a public forum for all to see ,are you on old or new points? if you jioned after jan of this year then you are on new rewards,you can't switch to old
12-03-2022 02:32 PM
hi @2299 you can opt out to the Public Point system, but once you opted out, you won't be collecting any rewards at all
There is no more cash taken off like the old rewards system now. On your new rewards system, collect 15 points and redeem for $15 bill credit
