traveling to myrtle beach
12-03-2022 05:48 AM
I traveling to myrtle beach via watertown. if I buy the usa data plan what are the odd of it working. I hear people are having problems?
Thanks
JOhn
Add-Ons
12-03-2022 03:24 PM
thanks I will check the map coverage, I more interest in the drive down to myrle for my google map not in mryrle. Thanks a bunch
12-03-2022 09:44 AM
@johnpublic you will be using T-Mobile for roaming in US. With data and text, you can use it's LTE network, which should be ok. With voice, you will be using it's 2G network.
According to the coverage map, T-Mobile has full LTE and 2G coverage in Myrtle beach
https://www.gsma.com/coverage/#466
But honest, 2G is an older network, so, the voice part might not work that good, Data and text should be ok
Worst case, if it does not work well, you can open ticket with PM support and share the experience, they will usually compensate based on how bad it is
And download VoIP app TextNow for free calls to Canada/US using the app. Just in case data work but voice not, you can use TextNow to call and receive calls
12-03-2022 08:15 AM
Hi John...
I used the USA add-on when travelling to Washington, DC in October.
I had absolutely no issues. Talk, Text, Data add-on all worked perfect. I used all three add-ons while travelling.
No issues on my return to Canada. Everything worked completely seamless.
12-03-2022 06:29 AM
@johnpublic wrote:I traveling to myrtle beach via watertown. if I buy the usa data plan what are the odd of it working. I hear people are having problems?
Thanks
JOhn
USA data add-on should be fine, but talk add-on almost won't work. So I think you'd better to buy a local sim card or using something likes TextNow that use data or WIFI to make a call.
