No MMS texts
phoneitin
I've tried resetting my APN, removing my SIM card, and rebooting my phone multiple times without any luck getting an MMS to send. I've also looked at several of the past threads with similar and tried various configurations that were proposed as a solution. What should my next step be?
@phoneitin
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and you can try to reset network settings on an IPhone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
click Here link,
How to reset network settings on an Android device
  1. Open the Settings app on your Android.
  2. Scroll to and tap either "General management" or "System," depending on what device you have.
  3. Tap either "Reset" or "Reset options."
  4. Tap the words "Reset network settings."
   or visit  Here link,
and go Changing APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
for iphone  go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet wifi is on is not going through the Picture or a video Messaging,
you have to do this to is going through you will need to turn your data on to send a Picture or a video Messaging in world-wide,
make sure your Data is on.
darlicious
@phoneitin
Yes the make and model of phone and a screenshot of your APN settings would be extremely helpful. If its an LG phone you may need a network and/or factory reset.
Compare your APN to this one....make changes if needed and save.
Name
Mobile Internet
APN
sp.mb.com
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
http://aliasredirect/proxy/mb/mmsc
MMS proxy
mmscproxy.mobility.ca
MMS port
8799
MCC
302
MNC
220
Authentication type
Not set
APN type
default,mms,agps,supl,fota,hipri
APN protocol
IPv4
APN roaming protocol
IPv4
APN enable/disable
APN enabled
Bearer
Unspecified
MVNO type
GID
MVNO value
4D4F
You have to have DATA enabled in order to receive MMS.
Receiving/sending MMS will Not use your data allowance (as per plan). You might see some small amount of data used as OS and background apps might communicate over the Internet (updates, refresh, etc.) but it has nothing to do with MMS.
@phoneitin I assume you already have Mobile Data enabled.
Just want to confirm,  what kind of phone do you have?
is this an issue after recent activation or change of phone?  Or you have been with PM for sometime and it has been working well before on the same phone and just stopped working?
Triguy
Try posting a screenshot of your APN settings.  What brand and model of phone do you have ?
You may need to do a network reset.
