No Data access with my phone.
06-03-2022 08:04 PM
I have absolutely no access to my public mobile data since mid April since I switched to a new android phone (the phone calling still works). I would request to speak to a live agent asap to sort it out.
Service
06-03-2022 08:19 PM
Live chat is available to some customers. However, if can't be requested but rather something that may be offered by Public Mobile on a case by case basis. To me, this sounds to be a device issue rather than some thing that a customer support agent would be able to help with.
06-03-2022 08:16 PM
@CHAN2 wrote:I switched to a new android phone (the phone calling still works). I would request to speak to a live agent asap to sort it out.
@CHAN2 What kind of Android phone is that? Brand and model?
It likely an APN issue, but could also be device related , especially since you have a new device.
06-03-2022 08:12 PM - edited 06-03-2022 08:13 PM
@CHAN2 It sounds like your phone settings
first thing do a data reset if that doesn’t fix it check apn settings
Step by Step APN configuration
Step1:
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Blackberry
OS 10 - Settings > Network and Connections > Mobile Network > Tap the settings icon (dented wheel)
Windows
Windows 8 Step 1 Settings > cellular > Add or Edit internet APN
iPhone
Step 2:
You will need to input the following information:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank
Step 3:
Select Save/Done. Select Public Mobile to connect to the Public Mobile network
06-03-2022 08:11 PM
Likely APN settings. What is the make and model of the phone?
06-03-2022 08:07 PM
No live agent to speak to here...this is a Community Forum, made up of users just like you and me.
Data is enabled on phone ?
