04-02-2025 01:29 AM
I have been a public mobile customer for 8 months. RCS has always worked. Today I had to switch my US number from att back to tmobile. RCS with Public connected but tmobile didn't. i turned off tmobile and restarted the phone and finally tmobile turned on but my public mobile keeps saying setting up. I have cleared cache, data, uninstalled reinstalled. Disabled my other number all to no avail Public is stuck on setting up. I have thrown my hands up at this point
04-02-2025 11:20 AM
if you are not in Canada now, I think that is the reason, you need to be on the network of that phone number to register.
04-02-2025 11:02 AM
I will leave it off. Have been using public mobile as the main whenever I am in canada. I am just frustrated that I have been dealing with RCS issues for 5 years. off and on. Had a smoth run for almost 2 years and then it just stops. Its pulling at my last nerve and its so fragmented with android. I have been loyal since 2008 but I may just jump to a platform that works and unfortunately that is apple.
04-02-2025 10:30 AM - edited 04-02-2025 10:31 AM
Dual sim support should be out of beta now.
No, i don't think it is an issue with Public Mobile. Try re-register RCS after 24 hours (and you have Public Mobile network active now? you probably cannot do that if you are in TMobile network only )
04-02-2025 10:06 AM
I'm on the beta and everything has worked flawless since November for me. I've even switched devices and back several times and never has an issue. I'm wondering if this is a public thing
04-02-2025 09:49 AM
RCS for dual sim support is only a recent thing, since Jan or so. Make sure your RCS is on the latest version
but some people said it didn't work well, it crashes.
04-02-2025 09:43 AM
don't kill it. Sometime you just need to wait..
04-02-2025 09:41 AM
Unfortunately that doesn't work. uS sim connects public says setting up, trying to verify number
04-02-2025 09:10 AM
Good to know. Didn't port a us number. Just switched carriers with us mobile.
04-02-2025 08:39 AM - edited 04-02-2025 08:40 AM
if I read it correctly, you didn't port your US number to Public Mobile, you just port your US number to T-Mobile.
in your RCS case, try uninstall Google Message (it will in fact restore back to the version it came with the phone), then reboot your phone, reinstall (or it might show update) Google Message. (you might need to enable RCS for both sims agian) and It should then work.
04-02-2025 04:43 AM
You can’t port an American number over to PM. You can only port a Canadian number through the PM app. Also the website and app are down under maintenance.
