No 5G
05-11-2024
04:55 PM
05-12-2024
07:35 AM
computergeek541
Hello all. I had changed my phone, bought a new esim and activated it. My phone number stayed with me but now I have no 5G, only LTE+. Changed to select 5G.
edited by computergeek541: profanity removed
Service
05-12-2024 06:59 PM
PM esim, yes Canuck
05-11-2024 05:10 PM
hi @Avn1007123 which eSIM you had with 5G?? PM?
is yours a Canadian version??
05-11-2024 05:07 PM
Hi, had esim before with 5G speeds
05-11-2024 05:06 PM - edited 05-11-2024 05:06 PM
@Avn1007123 I saw a post on Koodo about this with a Pixel 7, and customer service was able to fix it. So you might want to submit a ticket (use the chat icon bottom right).
05-11-2024 05:05 PM
@Avn1007123 946mbps is close to 120Mbps, ok speed
if you had it working before on PM physical sim and just not eSIM, ask PM support agent
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
05-11-2024 05:05 PM
sry, had wifi on!
05-11-2024 05:02 PM
hi @Avn1007123
it might be a Pixel issue as I see some people talked about it
is that a Canadian or US version of Pixel 7?? OS updated??
05-11-2024 05:02 PM
Hi, Can download @ 946 mbps and upload around 852
05-11-2024 05:01 PM
Things were fine until I purchased a new Esim and activated it in my P7P. My plan is 5G with 50 gigs data and I have a 5G transmitter up the block!
05-11-2024 05:00 PM - edited 05-11-2024 05:01 PM
Hey @Avn1007123
Even if the 5G doesn't show up on the screen, do a speed test. That to me is what counts. If you're able to get 5G speeds, you're doing just fine. 5G Speed¹ up to 250mbps
05-11-2024 04:58 PM
Pixel 7 pro. Upgraded from Pixel 6
05-11-2024 04:57 PM
hi @Avn1007123 to help you, we need to know what model of phone you have
