Nexus 6P Hangouts APN
11-04-2016 07:40 PM - edited 01-04-2022 01:11 PM
So I could'nt get Hangouts SMS to send an MMS APN setting were all correct . So I tried the default sms for Google and everything works fine now.
The 6P is on the latest 7.1.1 Androis Beta.
Has anyone had success with hangouts SMS sending a picture?
Phones
11-08-2016 07:12 PM - edited 11-08-2016 07:18 PM
I feel your pain, It has sometyhing to do with the file size setttings I think as I can send small pictures no problem.
11-08-2016 05:47 PM
Having this exact same issue with my Nexus 6P trying to send MMS from Hangouts. Get a failed to send message every time. I've tried every set of APN settings and tweaks I could find in the forums and nothing works. I've had to change SMS (MMS goes along with it) to Google Messenger as I can send MMS from that app. Not ideal!
11-07-2016 11:49 PM
Can you send screenshots of your apn settings?
11-07-2016 08:28 PM
Thanks, I tried this and still the same issue .
Chrome default browser
11-07-2016 06:33 PM - edited 11-07-2016 06:52 PM
Hi @computer
Did you change your default browser by any chance?
Please reference this thread in the google product forums:
https://productforums.google.com/d/msg/hangouts/GI_GoaFWzRI/f-Ji_4QsBwAJ
Look halfway down for an Update by Chris, the community manager if the link above does not take you there. It's a long thread so it may take up to 15 seconds for the browser to snap to the correct post.
My problem was that I had installed Opera and made it the default. Weeks later, I discovered that I could not send MMS messages via Hangouts. Then I stumbled upon the thread and when I put Chrome back as default, MMS started working.
11-04-2016 09:28 PM
11-04-2016 09:07 PM
11-04-2016 08:28 PM
I'm tagging @srlawren for you now as your message will shortly drop off the landing page. I recall he uses Hangouts.
