02-21-2023
07:41 PM
02-21-2023
07:45 PM
computergeek541
I bought a new sim card activated it and put in my mi 9t phone. For some reason it wont connect to the network. It worked with the old sim. I tried it on a friends Samsung A3, same thing. I put it in an old LG Nexus and it works.I cant figure this out
02-21-2023 11:15 PM
I used the proper adapters so they would fit
02-21-2023 11:14 PM
Yes, it's valid. There's a signal.
02-21-2023 08:12 PM
@dymd3z you can check here for service outage.
https://www.telus.com/en/on/outages
Check that you account is still valid and you've got signal of course.
02-21-2023 08:00 PM
My phone suddenly won’t connect to the network either. I tried rebooting my iPhone and resetting the network settings that the chatbot suggested. Nothing works. Surely this is an error on public mobile’s end?
02-21-2023 07:50 PM
@mwdawg Is it the size of SIM? The 9t and A3 use nano SIM and the LG Nexus uses micro SIM. Maybe that's the problem.
02-21-2023 07:44 PM
@mwdawg Try rebooting the device , otherwise you may need support to rest your account and re provision the sim
Watch for reply top of page to the
Right ( envelope image )
