04-25-2019 12:44 PM - edited 01-05-2022 04:36 AM
Hello,
New to Public Mobile - Not receiving calls - Moderators not responding for 3 dys now...
iphone 6s
Removed sim - turned on and off
Sent private messages to moderators no response
Can call out and receive/send text messages
Cannot receive calls goes to old voicemail
Thanks!
04-25-2019 01:01 PM
@emere wrote:Yes ported from other provider, no old sim is no longer working. Yes guess I will have to wait for the moderators. Thanks.
You should receive a text from PM when the port has been completed. Hopefully it gets resolved soon.
04-25-2019 12:56 PM
04-25-2019 12:56 PM
@emere wrote:Yes put all info into the old account #, name etc.
Yes it is going to a old automated voicemail. So if it hasn't ported properly what can I do?
Thanks
Unfortunately I believe you need a MOD to help but I assume they are overwhelmed with messages about the system error that has been going on.
Perhaps message again? Maybe the Oracles will have a solution to help give the port a kick....
Hope you get working soon!
04-25-2019 12:51 PM
Thanks
04-25-2019 12:51 PM
@emere wrote:Hello,
iphone 6s
Thanks!
Are you porting your number from another provider? That would explain why you can't receive calls & texts. If it's three days then the port is stuck and you will have to wait for the moderators response. Keep checking the envelope icon above for a red dot.
Hopefully you account with the previous provider is still active. If it is you can still use your old sim until the problem gets fixed.
04-25-2019 12:49 PM
Did you port your phone number from a previous carrier?
If yes, its likely that the number hasn't ported completely. Does your old sim still work?
04-25-2019 12:49 PM
If it's going to your old voicemail then your number has not been ported properly.
Did you enter all info (old account #, name,etc) when porting?
