New sim card with monthly plan on my existing account?
06-16-2019 09:40 AM - edited 01-05-2022 05:25 AM
06-16-2019 03:05 PM
@GinYVR I believe the cc issue is more probable to happen If renewals happen on same day. I believe they are done in batches and when cc company sees two renewals at almost same time alarms are raised.
06-16-2019 02:21 PM
@TiptopssssYour *could* use the same credit card, but don't be surprised if it is rejected.. Public Mobile's payment system is quirky. I suggest have another cc # ready just in case, if the same one works that's great.
06-16-2019 01:13 PM
@Tiptopssss wrote:Hi, I'm looking to buy a sim card and activating it with a monthly plan for my daughter, can I do that with my online account I have now? I would just like it to come out automatically every month from the account that I have now. Is this possible? Thanks
If daughter has her own email, just register with hers. As already suggested...you can use the same cc.
Good luck,
06-16-2019 09:59 AM
If you use Gmail you can use a Gmail alias name+123@gmail.com is the same as name@gmail.com
06-16-2019 09:52 AM - edited 06-16-2019 10:29 PM
@TiptopssssEvery SIM card requires it's own account, phone number, and email. You can use the same credit card for both accounts but should try to avoid having the same renewal date as multiple simultaneous charges can be flagged as possible fraud and blocked.
06-16-2019 09:46 AM
No. You can use the same credit card though.
