06-13-2023 04:18 PM
Hello. Can you please verify if I will get 90GB for 3 months?
how long do I get the extra +15GB?
06-13-2023 08:59 PM
@dylalee 90GB for 90 days. All 90GB will be give to you on Day 1 for you to use within 90nsays
06-13-2023 08:50 PM
I am confused now. How much data do I get over 90 days?
@CS_Agent in our Community
06-13-2023 07:14 PM - edited 06-13-2023 07:18 PM
Sorry, misread plan. Deleted post.
06-13-2023 05:31 PM
06-13-2023 05:21 PM
you'll have 90GB for your use in 90 days...you can use it all up in a week or stretch it out over the 90 days. When your next regular plan renewal occurs, you'll get another 90GB's of data for the next 90 days usage.
06-13-2023 04:52 PM
@dylalee wrote:I am an existing client and I know how to change the plan. Just need verification if I get the 15 + 15 GB every month? And if all of the data is given at the start of the month on a 90 day renewal.
Public Mobile doesn't have monthly plans. The plans are either 30 or 90 days. 90GB is given when the plan starts. The plan can be changed by pre-scheduling a change to occur when youl would have otherwised renewed. This can be done from your Self Serve account.
06-13-2023 04:44 PM
06-13-2023 04:22 PM - edited 06-13-2023 04:22 PM
@dylalee did you just join or you are existing member just click Change Now when you make the plan change?
If you are , then just login My Account once more using Incognito mode, you should see the plan details on the Overview page as well as Subscription & Add-ons page. You should see the full 90GB there (for use for the next 90 days)
