New plan with 4G speed ?
miicmc
"Hi everyone, I switched my mobile plan from 3G to 4G last December during a promotional offer. I have been using 4G for a few months now and need some help. I am using an iPhone 14 Pro and on the top right of the cellular icon, it shows LTE instead of 4G. In the Voice & Data settings, I can only switch between LTE and 3G. I am wondering if I am really getting 4G speed. I used Speedtest to check my download speed which was 102Mbps and my upload speed was 9.63Mbps. Thank you."
dust2dust
You're getting faster than the advertised speed so seems it's doing its thing.
Let us know if you go to the states and buy a roaming talk bundle.
@miicmc
Please note that 4G/LTE are the same.
Meow
LTE = 4G.
You are on correct G
@miicmc   you are good.  LTE=4G.  Download speed you got 102Mbps is correct
@miicmc  LTE /4G is the same thing your all good
