12-25-2023
11:32 AM
12-25-2023
01:22 PM
computergeek541
12-25-2023 11:55 AM
Just take it out of your existing device and put it in your new device
done
12-25-2023 11:49 AM - edited 12-25-2023 11:50 AM
@LittleT94 !just take the simcard out of your old phone and put it into your new phone . If the tray for new phone appears smaller then your old one know you can just take the outer edge off the SIM card to make the right size for your new phone
3 hole punch /desired size
Note flat edge corner / fit flush in tray
No lifting or rising /push in all the way
12-25-2023 11:43 AM
Currently have public mobile. Trying to change existing Sim to new phone
12-25-2023 11:43 AM - edited 12-25-2023 11:44 AM
@LittleT94 and FYI, these are the bands your phone has and bold are compatible ones
these are the bands your phone has, bold are compatible bands
3G bands HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100
CDMA2000 1xEV-DO
4G bands 2, 4, 5, 12, 25, 26, 41, 46, 48, 66, 71 - USA
5G bands 2, 25, 41, 66, 71 SA/NSA/Sub6
12-25-2023 11:42 AM
yes, it will work.
and make sure you click Reset All networks when you put your PM sim card into it
12-25-2023 11:41 AM - edited 12-25-2023 11:42 AM
12-25-2023 11:40 AM
V60 Thin Q 5G UW
12-25-2023 11:38 AM - edited 12-25-2023 11:39 AM
the easiest way, is ask someone who is currently with Public Mobile to use their physical Sim card in it to see if you can make and receive calls, texts, and use data
it’s just a matter of popping the Sim card out of their device and inserting it in your device.
then, once the test is done, simply take it out of your device and put it back in their device.
12-25-2023 11:37 AM
tell us the model of your phone and we can help
12-25-2023 11:36 AM
How do I check this
12-25-2023 11:35 AM
tell us what phone do you have and we can help
To make sure your phone works on PM network, make sure your phone has these bands:
5G = NSA: n66, n78
