New phone
07-11-2023 10:53 AM
07-11-2023 11:05 AM - edited 07-11-2023 11:07 AM
Just take out the SIM on your old phone and put it in the new phone. You might have to remove or install a spacer depending on the SIM tray size.
Reboot your phone by powering off the phone then power back on.
eSIM…can’t be done yet.
07-11-2023 11:04 AM
@KM9 Take SIM card out of old phone and put it in new phone that’s it nothing more . Easy peasy
07-11-2023 10:55 AM
@KM9 you are using physical sim and not esim?
all you need to do is to remove the sim from old phone, put it in the new phone and it will work. Beauty of physical sim
Of course, you might want to backup your data from the old phone to cloud and then restore it to your new phone to make setup easier
07-11-2023 10:55 AM
You just have to pull out SIM card and stick it into new phone. Use appropriate SIM adapter is SIM slot is different.
eSIM is not transferrable, yet.
