06-06-2020 06:00 PM - edited 01-05-2022 11:03 AM
I put the new pm SIM card in the new to me Unlocked iphone7.
my previous phone I disabled on public mobile website as lost / stolen
On the pm website, it says change SIM card option, I did that and entered the number from the SIM card
i got a message saying already in use, or something
restarted phone, still says no service
how can I get my old phone number And plan onto my new phone
06-06-2020 07:49 PM
@qcriderfan87 why are you doing this? Just insert you sim card from the old phone and everything should work. Who told you to use the lost stolen option? No need!!
06-06-2020 07:38 PM - edited 06-06-2020 07:39 PM
If you reported you phone lost or stolen,
1. You need to report it is found.
2. Change your SIM card to the new one your have.
3. Insert you new SIM card to your iPhone 7
4. Restart your iPhone 7 and let your new PM SIM card to configure your iPhone 7 automatically.
If you did all these steps and your iPhone 7 is still not working, follow @gblackma instruction to connect your iPhone 7 to a PC running iTune.
06-06-2020 06:07 PM - edited 06-06-2020 06:08 PM
@qcriderfan87 did you remove lost stolen on the account? Try these 2 things in order.
Restart your phone if it doesn't, reenter your wifi if applicable, enter sms and mms to send and receive from Android phones. Emavle data amd try to send an mms text message and to surf the net. Stay safe.
06-06-2020 06:04 PM - edited 06-06-2020 06:05 PM
@qcriderfan87 try using your browser in incognito/private mode and try changing your sim again
also take your account off of lost/stolen mode
06-06-2020 06:04 PM
Did you also report your phone found in your self service account?
Then reboot the phone with new SIM card.
