05-06-2020 12:07 AM - edited 01-05-2022 10:40 AM
05-06-2020 12:53 AM
@Anonymous Yes, both plan data and multiple data add-ons.
05-06-2020 12:50 AM
@geopublic wrote:@Anonymous It appears to be reporting all data usage.
So you have plan data and maybe some add-on data?
Thanks for checking it. Cheers
05-06-2020 12:39 AM - edited 05-06-2020 12:49 PM
@Anonymous wrote:
@geopublic wrote:@Asante1 You can also dial *611 from your device.
@geopublic (or anyone interested)
If you're on a plan with data and have some left would you be willing to try calling 611 and see what it reports for data remaining?
Is it all data or just add-on data if present?
I know it doesn't report limited plan minutes and I don't have plan data.
05-06-2020 12:26 AM
First go to your self serve account then right under the change plan button in the over view page you will see, view usage.
click on that and you will be brought to your usage.
05-06-2020 12:21 AM - edited 05-06-2020 12:21 AM
05-06-2020 12:15 AM
05-06-2020 12:11 AM
05-06-2020 12:09 AM
@Asante1 wrote:Hi how do I check my minutes calls and data ?
The self-serve overview page shows you your data counter and if on the $15 plan - the minutes counter for outgoing calls.
You can also go into the usage details to see all the activity going in and out of your account.
05-06-2020 12:09 AM
Log into self service. https://selfserve.publicmobile.ca/
