03-03-2021 07:48 PM - edited 01-06-2022 02:14 AM
Just signed up a new Public subscbriber . Phone number seems to have ported successfully.
Text works fine ...she can call me , but when I dial her number I get " The customer you are calling is unavailable at the moment ..please try again later " ...to be honest , it sounds like her old provider , Rogers ? We haven't set up voicemail on Public but I confirmed with her that when I dialled , her phone did NOT ring . Any help appreciated . TIA
03-22-2021 02:14 PM
@Rajivbhatt42 : Are you Woomera? What's still not working? This is a solved thread. So that Woomera doesn't keep getting notifications perhaps you could make a new thread and add more details of what the problem is.
03-22-2021 01:58 PM
Still not working
03-04-2021 07:25 PM
Excellent. Enjoy Public Mobile!
Marius
PM MOD TEAM
03-04-2021 07:16 PM
Many thanks to the Moderators for all their help . Battling with try to port the number from the previous provider was too difficult ( their fault , not ours ) ...just easier to go with a new number ( which was my first thought anyway ) . Everyone was super-helpful ...Public's the best !
03-04-2021 03:49 PM
Woomera,
If you need assistance send private message to Moderator_Team and provide details about the issue.
Public Mobile
03-03-2021 11:15 PM
03-03-2021 10:57 PM
Thanks for the reply ...working on a solution with the Moderators
03-03-2021 10:51 PM
@Woomera wrote:Just signed up a new Public subscbriber . Phone number seems to have ported successfully.
Hi @Woomera log in your self serve account. Click the Plan anad Add-Ons tab. If you see the number you are porting there, then Public Mobile has already assigned that number to your PM account. Activation complete, but porting failed. In this case, call the Port Team number provided by @esjliv here. Please note that this number is only to be used for porting problems.
Put back your old sim card in your device to receive verification text from Rogers. Use the Rogers sim card until it stops working, which means that your port is complete.
Please be sure that your Rogers account is active to port a number. If you are not that attached to your number, changing your number is the best thing to do.
Welcome to Public Mobile
RosieR
03-03-2021 08:56 PM
If you're not attached to your prior number that you were trying to port, I would go ahead and try the Change Number option.
One and done.
03-03-2021 08:55 PM
Tried the Chatbot but didn't get a prompt to contact a Moderator , so send an email msg. Awaiting reply . Thanks for the help
03-03-2021 08:45 PM
@Woomera wrote:Thankyou ...I believe you are correct ...will review the link you posted . We joined Public on Sunday hopefully allowing enough time for the port as it expires with Rogers tomorrow I believe ? Can I just request a new Public number instead ?
@Woomera , if this was a cell phone, that is too long.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
Type "port issue"
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
03-03-2021 08:42 PM
I think that might be the easiest option . The original Rogers account was not set up properly although we DID have the correct PIN ( but no other information ). I thought it might cause a problem . I'm familiar with the CHANGE NUMBER screen in Public ...if that will work , it will be our easiest fix ...Should I try or will the failed porting cause a problem ? Thankyou
03-03-2021 08:40 PM
Yes you can, @Woomera
You can change your phone number once every 30 days after you have activated. To change or transfer your number after activation, go to your Self Serve Account here and:
03-03-2021 08:35 PM
03-03-2021 07:55 PM
@Woomera , your number port did not succeed. What is happening is you are not using your Rogers SIM card and calls are still going to that number which is not connected to the network and thus the customer is unavailable notification. Please review and follow the steps required to recover the number port. Good luck and welcome to Public Mobile
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
03-03-2021
07:50 PM
10-09-2023
08:40 AM
@Woomera - Welcome "New Subscriber"!
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If it takes more than 4 hours call the Porting Team
