01-16-2019 08:11 AM - edited 01-05-2022 06:30 AM
I recently bought a new phone (Zenfone 5Q) and for some reason it will not connect to data at all. It doesn't show that it is trying to connect to data. Under settings it says that data is enabled and my plan is supposed to come with data. Does anyone know how to fix this issue?
01-16-2019 11:59 AM
@Alex888 wrote:Have you tried turning your wifi off? Make sure it's not in data saver mode. Check that the prefered network is set to Auto.
You can also try turning Airplane mode on for 30 sec then turn it off, if it still doesn't work turn your data off, turn airplane mode back on, turn your phone off, leave it for a minute, turn it on, turn off airplane mode, wait 30 sec, turn the data on.
@Alex888 these are good suggestions, but for future reference, whenever you see "zenfone" or "asus", it probably requires manual APN configuration. I'm not sure why, I guess Asus donesn't include Public Mobile APN info in their firmware for whatever reason.
01-16-2019 09:18 AM
Thank you to let us know @Meg93!!
01-16-2019 08:30 AM
Thank you so much! That worked 🙂
01-16-2019 08:28 AM
01-16-2019 08:19 AM
Sorry for the mixed with the pictures.... when it says: laisser ce champ libre ... it means don’t write anything...
01-16-2019 08:17 AM
01-16-2019 08:15 AM
Hello @Meg93.
you can try to configure your APN settings.
