02-25-2024 12:35 AM - last edited on 02-26-2024 12:18 AM by computergeek541
I see some new long needed Canada-US Plans are now available with Public Mobile.
I am currently on the classic $50 • 40GB Canada-US Plan and I want to change to the new $50 • 100GB Canada-US Plan, I just need to make sure of something first..
On 'My Current Subscription' it shows I currently have 40GB Canada-US Data at 5G Speeds, the new 100GB one only says '100GB at 5G Speeds'.
So I just want to make sure this is indeed still US Canada Roaming Plan so I can use my data in Canada and the US since I am in the states very frequently - as you can see the new one doesn't clarify that it's Canada-US Data like the old one does.
02-25-2024 11:01 PM - edited 02-25-2024 11:02 PM
So to be sure, since I'm currently in Las Vegas I activated a 75GB and a 100GB with new numbers to make sure they work here in the US.
Both work here, but the 75GB and 100GB are not getting proper 5G Speeds.
My classic 40GB Canada-US Plan is getting full 275mbps on my S24 Ultra, and the 75GB and 100GB (New US Plans) don't seem to get anything better than 20mbps.. making things take so long to load sometimes.
02-25-2024 11:00 PM
It's the same footnotes for every plan, even the Canada Plans say the same thing.
02-25-2024 10:23 AM
Look under "Details" and the ++ footnote that confirms what others have said. The ad-copy writers and lawyers need to communicate better with each other.
02-25-2024 03:38 AM - edited 02-25-2024 03:41 AM
Yes you will still able to have CN-USA plan in USA if you make the changes. You are just getting more data but still the same to use anywhere in Canada and USA.
02-25-2024 12:38 AM - edited 02-25-2024 12:41 AM
@Priority - If you go on the official website it says 100GB in Canada & the USA. So you will get 100GB of capped data in both Canada & the US. Despite it not clarifying that in the My Account Section, it still is the same data allotment in both Canada & the USA.
