03-01-2024 03:43 PM
Just confirming if $34 CAN-US plan support 2FA SMS messages to same number while I'm travelling in the US?
Plans
03-01-2024 09:17 PM
You actually don't need a US plan or a roaming add-on to be able to receive text messages while in the US (including 2FA/OTP). Incoming text messages are free in the US, even without a US plan/roaming add-on. That said, the current Canada/US plans would be amazing even if they didn't include the US.
03-01-2024 03:51 PM
@HootieG88 , this plan will function just like it does in Canada when you are traveling in the US
03-01-2024 03:46 PM
Yes, this plan supports 2FA SMS text while traveling in the USA.
03-01-2024 03:46 PM
YEP...SMS will work as expected on both sides of the border.
