Network locked SIM card inserted
11-18-2016 09:45 PM - edited 01-05-2022 12:37 AM
Hello, I just transferred my SIM to a new phone (worked in the prior phone) and it says network locked sim card inserted. The phone I bought was supposed to be unlocked. I just activated this week.
Is this an issue with the phone or could it be an issue with the SIM?
I had in a blackberry, now it is in a Samsung G6.
Service
11-19-2016 12:13 AM - edited 11-19-2016 12:14 AM
It's definitely locked to some cell phone provider. If it were unlocked, the phone would not be saying network locked/invalid sim/asking for aa network NCK code. Being unlocked doesn't always mean compatible but even an incompatible phone wouldn't give you such an error message; it just wouldn't be able to connect to your network.
In the past, there have been phones that have been "personalized". A personalized cell phone differed from an unlocked phone by that it would only work with one other company's sim card. Because of that, you really need to try sim cards from at least 2 other providers other than the original locked carrier. I haven't seen a "personalized" phone in a while, but it's always still a possiblity, especially if it's an older model.
11-18-2016 10:55 PM
11-18-2016 10:38 PM
11-18-2016 10:23 PM
does it have to be another company? tried another public mobile, didnt work
11-18-2016 10:01 PM
You can try different companies' sim (if you have any to try). That way you can rule out if it's locked or not.
11-18-2016 09:58 PM
Bought it from a cell phone reseller... ill have to go back tomorrow...
any instructions if not locked?
11-18-2016 09:50 PM
Most likely your phone is locked. Where did you buy it from?
