02-23-2025
11:22 PM
02-23-2025
11:31 PM
computergeek541
I got two SIM cards for PM from Amazon for me and my wife. I went and activated the first one as per PM instructions and selected a subscription and paid, received a new number etc. Then inserted the card into my phone. Completely dead, tried in my wife's iPhone, still dead, reboot, network resets. Popped in the second card and it instantly reads it. The problem is I can't receive SMS to confirm the setup of my account so I'm locked out from making any changes or using my wife's (not setup) functioning SIM card and transferring my number to it.
I'm subscribed but completely locked out essentially because my number to confirm is tied to a DOA sim card so I was never able to fully setup my account.
Please help!
02-23-2025 11:56 PM
Thanks ticket submitted
02-23-2025 11:55 PM
Sorry, if I wasn't clear but the SIM card will not register/read my phone at all. It thinks nothing is installed. Old Rogers sim works perfect, non registered PM sim is recognized immediately.
02-23-2025 11:43 PM
Brand New number no porting. I wanted to just setup a new number and make sure I wanted to switch to PM if things went well and then port later.
02-23-2025 11:39 PM - edited 02-23-2025 11:42 PM
and if you cannot receive sms, it maybe just because porting is not done yet. With porting in progress, you will be only able to make outbound calls but won't receive inbound calls and texts
02-23-2025 11:36 PM
Thanks,
Ticket submitted
02-23-2025 11:36 PM
Hey @Kvancaeyzeele
I had a similar issue setting up/switching my old number to my new SIM card as well. Don't sweat it too much, these things can happen when switching providers. Like the others have said, submit a ticket and an agent will get back to you with a message in a couple hours. They are very good and helpful & fixed my issue right away.
All the best
02-23-2025 11:27 PM
you will need support agent to check with account activation and the setup of the sim card on the system.
you can submit ticket by direct message:
02-23-2025 11:27 PM
should be just a sim card provisioning issue, easy fix for PM support. Just message them at:
