Network Issues and Texting
Tee3000
Hey, is anyone else having problems with only 1-2 bars on the Public Mobile network?? Or having texts not going through?? Over the weekend several people said they didn’t get messages from me and I didn’t have a service interruption so I’m very frustrated and considering cancelling this service since it doesn’t seem to work.
Phil_Adelphus
I pretty much always only have 1 or 2 bars (rural area) and my phone seems to work fine.
@Tee3000 the bar can be misleading. 1 or 2. bars are good enough for many situations, especially with text
If you are on Android , try to clear cache first.  Of issue persists, you might want to download Google Message and set it as the default messaging app
if you are using iPhone, make sure Carrier profile is updated
@Tee3000  Try your networks setting on 3G or 5G assuming you’re already on 4G/LTE and test it out in different areas . Also check
Outage map in your area:
https://istheservicedowncanada.com/
