09-17-2023
09:37 PM
09-18-2023
12:08 AM
computergeek541
Looking to replace an Asus Zenphone 3 with a shattered screen. On the $25 plan. Would like a reasonably priced phone that can pick up the Telus LTE and 5G bands. In the past I was able to see a list of compatible phones, but now I cannot find it. So can someone provide a list of compatible phones. Also, I thought PM sold phones, but I cannot find the link. Does PM sell phones?
Thanks
09-18-2023 01:48 AM
Thanks Softech.
I see that Telus/PM use 5G bands N66(1700) and N78(3500). The Moto edge 2022 has N1(2100), N41(2500) and N78(3500). Does it matter that the phone is only compatible with the N78(3500) band?
09-18-2023 01:02 AM
Telus seems to have directed their little outfit here to have more restrictions on which devices will be allowed. I wouldn't use Telus references.
09-18-2023 12:53 AM
Telus have the 2022 Edge listed for sale on their site:
https://www.telus.com/en/mobility/phones/motorola-edge?INTCMP=tcom_mob_catalogue_to_motoedge(2022)
The specs say it has VoLTE. I suppose I have to buy the phone from Motorola, then check the IMEI. Is there a hard rule that Telus will only accept IMEI's from phones they sell?
09-17-2023 11:42 PM
@Yurong Moto edge 2022 is on PM VoLTE whitelist
09-17-2023 11:34 PM
@Yurong , you can use this site to check if you have a device IMEI. I have another warning, I had a device which had functional VoLTE the first couple of months after the feature went live and out of the blue I lost it and have never been able to recover it. I am not saying my situation is the norm, you need to know it can happen and when it does, support has no solution. I expect to retire this device before the 3G network is taken out of service, I can live with this problem.
09-17-2023 11:26 PM
Glad I posted the question on this thread. Is there a way to check if the 2022 Motorola Edge is on the Telus VoLTE whitelist?
09-17-2023 10:55 PM
@Yurong , getting a compatible phone is not so challenging. Pretty much anything sold in the North American market will work. The problem is with VoLTE compatibility. Telus maintains a pretty short whitelist. Without VoLTE, your phone will have a 2025 death clock when the 3G network is scheduled to be removed from service.
09-17-2023 10:26 PM
Very nice choice for an affordable phone. This of course will work.
09-17-2023 10:00 PM
09-17-2023 09:59 PM
@Yurong Yes that phone will work
09-17-2023 09:58 PM
So this phone should work?
09-17-2023 09:50 PM
Most phone available in Canada should work. If it is a foreign phone, just check they have the frequency bands that Telus uses
09-17-2023 09:41 PM
@Yurong Sorry PM doesn’t t sell phone anymore , check out mobile klinik for CPO phones . There apart of Telus also
09-17-2023 09:39 PM
HI @Yurong
it is too hard for any provider to keep a list of compatible phones, there are just too many phones out there
For the phone you want to get, it should work. Try to get the US version or Taiwanese version. Do not by the Indian version as it does not have all the bands PM needs
09-17-2023 09:39 PM
Hi @Yurong
Public Mobile no longer sells phones. If you want to be on the 5G network, look for a phone that supports 5G. It's that simple.
