08-04-2023 07:10 AM
Does this have the Unlimited Data Plan included?
Comparing the TWO Almost Identical Except Speed differences Plans, Is this 5G Unlim, Or not, and is it same as the 4G Can-US Wide where can use in BOTH Can and US?
08-04-2023 07:08 PM
Wow....Thanks for that info looks like I have a list of referrals to contact about scheduling a change plan on next renewal.
08-04-2023 11:33 AM
@Proxima , @hTideGnow , @Handy1 , @maximum_gato , Great News:
Hey there,
Yes, all 5G plans should have throttled data once you use the included monthly 40GB.
And yes, based on the information, it's pretty much the same thing, but with data at 5G speeds instead of 4G.
And since it's a plan with 5G data, you can use throttled data afterwards instead of just not having data at all until renewal as with a plan with 4G data.
If you are using a phone that's not compatible with 5G speeds, it will throttle it at the highest available speed, in this case, 4G. And you should still have throttled data up to 512Kbps if you use more than 40 GB during your cycle.
If you have any other questions, please let me know.
Thank you!
Christopher
08-04-2023 09:50 AM
HI @makkahn28
anyone can confirm we can use T-Mobile 5G during roaming?
if not, the 5G is only for Canada
08-04-2023 09:35 AM
Without a 5G phone the plans are then identical offering 4G LTE data up to 100mbps (but often exceeding 100mbps). If you cannot connect to the 5G network you cannot benefit from it.
08-04-2023 09:05 AM
The Only Good thing about the 2 Can-US Wide Plans
Regardless of 4G or 5G, at least that saves One $30 for the US Roaming Bundle that Only lasts 15 Days, and Only has 3GB Data
08-04-2023 09:01 AM
I know the $50 for Can-US Wide 4G LTE Advanced Speeds 100MB has No Unlimited Data Throttling
Wasn't sure on the $50 for Can-US Wide 5G LTE Advanced Speeds 250MB
Question, If one was on the $50 for Can-US Wide 5G LTE Advanced Speeds 250MB, and the Phone was Only 4G LTE Advanced, What would the speeds be?
08-04-2023 08:56 AM - edited 08-04-2023 08:58 AM
The only difference is the speed, both don’t have unlimited throttling if that’s what you’re asking,
The only plans that have a unlimited throttle (currently) are the the Canada only- 5G plans
08-04-2023 07:54 AM
Delicious
08-04-2023 07:53 AM
@makkahn28 gotta love bill reducing rewards 🙂
08-04-2023 07:50 AM
True, But, for the $50, and on my Old Rewards, I calculate that my savings would reduce plan fee from $50 to $42
08-04-2023 07:48 AM
@makkahn28 the 5G one would be best then in that case . But at the end of the day the best plan is the cheapest one that meets your needs
08-04-2023 07:46 AM
I know, But, Comparing the Plans, That has the Can-US Wide built-In, no need to buy US Roaming Add-On, between the $50 for Can-US Wide 4G LTE Advanced Speeds 100MB vs $50 for Can-US Wide 5G LTE Advanced Speeds 250MB
Which would be the Better Plan with Best Price?
08-04-2023 07:45 AM
@makkahn28 .it seems neither one of them has unlimited data . Which is strange because this the first time I seen 5G service that didn’t include unlimited data
08-04-2023 07:43 AM
Just curious, Does the 5G Version have the Unlim Data Or like the 4G where after reaching Data Allocation Cap, Data stops Unless Add-On Data is Purchased?
Also, If One has a Phone that Only has 4G But No 5G, will the 5G Plan work on the Phone that Only has 4G?
Will Speeds be Capped at 100MB, or Go up a bit on the 4G Phone?
08-04-2023 07:43 AM
@makkahn28 Sorry I know it doesn’t exist . I thought you were asking me what would be the perfect plan . I made that up for what I thought would be a perfect plan and price point . But for many I think the most attractive one right now would be 30GB $45. 5G unlimited 30 day
08-04-2023 07:39 AM
But the 50GB for $39 5G unlimited CAN /US Price does Not exist
It's Between $50 for Can-US Wide 4G LTE Advanced Speeds 100MB vs $50 for Can-US Wide 5G LTE Advanced Speeds 250MB
Which is more scrumptious?
08-04-2023 07:30 AM
@makkahn28 For me 50GB for $39 5G unlimited CAN /US would be a perfect plan
08-04-2023 07:23 AM
What would be the Perfect Plan with the Best Price?
50/ 50 Coin Toss
08-04-2023 07:19 AM
- @makkahn28 difference is speed ones 5G speed the other 4G speed . Both have 40 GB $50 CAN /US roaming
