Need to Add Device to Blacklist
Bead54
Hi,
My son lost his phone and we aren't able to locate it. I have the IMEI number and would like to get it added to the blacklist. How can this be done. I swapped out SIM cards so don't want to suspend service.
Thanks
7 REPLIES 7
WoozyPolarBear
Removed by user
@Bead54 wrote:
Hi,
Thanks
@Bead54  - Customer Support Agents (CSA) methods of contact can be found the the Help Articles, here, for future reference:  https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
Do you have a screen lock on the device (EDIT: with a message "If found...")?
Hopefully some good samaritan finds this and helps to find you/your son.
Bead54
Thx OPX. Msg sent.
Bead54
iPhone. It's locked. Just can't find it. Unfortunately the Public Mobile site isn't very straight forward about how to talk to a CSA to ask about adding to blacklist.
Yummy
From what I know, you would have to get in touch with mobile service provider. If that was PM, send private message to CSA.
@Bead54   What kind of phone is that?  Can you lock it, remote wipe or so with Apple, Google or Samsung's service?
0PX9O4
@Bead54
You can send a private message to CS_Agent with your account details so they can add the IMEI to the Canada-wide blacklist.
