01-11-2024
07:19 PM
01-12-2024
04:40 AM
computergeek541
Koodo says that the number porting was not completed and that Public Mobile needs to initiate it again or they will continue to charge me. Can I please get support for this?
01-11-2024 07:27 PM
Because it's an internal porting, you can always send a Private Message to a CS Agent to fix it for you too.
They usually respond with in a few hours or less.
01-11-2024 07:20 PM - edited 01-11-2024 07:21 PM
@PaulI51 Will send you the porting team number private message right away
check your inbox or use this link to the community in box for the number
