04-15-2024
09:31 PM
04-16-2024
12:17 AM
computergeek541
I just reset my iPhone and now my eSIM is gone !! How do I add it back to my phone !!
04-15-2024 10:38 PM
@Latinjojo - Did you use recovery mode or just normal iPhone reset?
You can stop eSIM from deleting on iPhone reset but not during recovery mode reset.
04-15-2024 10:00 PM - edited 04-15-2024 10:02 PM
Great! I know the first one is free after that... might want to consider physical SIM for the future. If you change phone, just have to remove.
Ask the bot if you can get a credit, I doubt it but you could try.
Adding, if you need to reset phone again make sure to disable esim first. You could enable after.
04-15-2024 09:57 PM
Thx you got my number back and eSIM working back on my phone sucks tho I had to pay for eSIM again tho wasn’t free ugh 😞 this should be free considering I already bought one from before
04-15-2024 09:55 PM
Since you login to My Account to get a replacement esim, the new esim will tie to the same account and therefore you will get to keep your phone number
04-15-2024 09:49 PM
Once you purchase the esim, go to Profile, scroll to SIM card, click the pencil to change the number. Save
04-15-2024 09:35 PM
Thank you ! But will I get my phone number back ? Is my question ?
04-15-2024 09:33 PM
HI @Latinjojo
you are lucky, getting a replacment esim is now Free
You just need to download the app on your new phone. Then go to Account page, choose Purchase SIM Card and then eSIM.
The app will check if your phone is eSIM compatible, and it shouldn't ask you to pay after confirming you already bought an esim before.
