07-31-2023 05:05 PM - edited 08-01-2023 06:17 PM
08-01-2023 04:37 PM
So I was porting to Eastlink - two public mobile numbers. One we never did get it to work. 2nd one: it used to be a Koodo number before we ported it to public mobile. Eastlink had no luck porting it as a public mobile number, but I had them try it as a Koodo number and it worked. 🤷♂️
07-31-2023 05:33 PM - edited 07-31-2023 05:34 PM
Thank you for the quick responses. I am on hold with support at the company I started to porting to yesterday. It seems my port request is hung up since yesterday - they are working on it. They just tried to port my old PM number over and their system says my number already has a port request 😬
07-31-2023 05:27 PM
If you are porting out of PM. You will need help from the carrier you are going to but leave your PM SIM in your phone and confirm to the text you are porting out of PM.
07-31-2023 05:08 PM
@KSteeves You need to initiate the port out request from your new carrier . Leaving your PM SIM card in the phone so you can get a confirmation text from PM to port number out . You then reply YES . You have 90 mins to do so .
07-31-2023 05:08 PM
if you're porting out of PM, contact your new provider for guidance.
07-31-2023 05:08 PM
have you started the porting out request yet?
If yes and you got into trouble, make sure your PM account is active and you can still receive incoming calls and text
Then call your new provider and ask them to re-trigger the porting request.
Wait another hour or two and you should receive that
If still not receive the text from PM asking you to approve the porting, please open ticket with PM support using this direct link: https://urlshortner.tiia.ai/Lc9xk8
Make sure that you respond to this text within 90 minutes. If you do not receive this SMS or you do not respond within the 90 minute window, make up to 4 additional attempts to send it. If you are still experiencing any difficulties, reach out to a Customer Support Agent
(Ref: https://www.publicmobile.ca/en/on/get-help/articles/porting-out )
if you have not requested porting number with your new provider, first, make sure your PM account is currently active and you can receive text without problem. Login to My Account and get the account number from Profile page https://myaccount.publicmobile.ca/en/account/my-profile
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
Now activate your new line with your new provider and request to port a number. Provide them PM's account number as the porting information
this is critical: Then still have your PM sim card in the phone, wait for PM to send you a text to confirm your porting request. You need to reply YES within 90 mins
After you replied yes, you can put your new sim card in the phone and wait until you get incoming calls. Once you are getting incoming calls, porting is completed. Your PM account will also be closed at this stage (you will no longer be able to login to PM My Account after)
