11-04-2022 02:33 PM
I purchased a cell phone October 18/22 and my money was withdrawn. As of Nov 4/22 I still don't have my cell in hand. How do I contact them asking for assistance? Thanks in advance.
11-04-2022 03:39 PM
I guess the only answer you will get 'we are processing your order' or 'your order is in the mail'. Just be a patient a little bit more as even SIM travel 2-4 weeks from PM.
If you have tracking number that would help.
11-04-2022 03:07 PM
Yes I did receive an email confirming my order. I did contact them the ways you suggested. Thanks for your help.
11-04-2022 03:06 PM
I followed your advice and contacted them as you suggested. Thanks so much.
11-04-2022 02:47 PM
@banana29 Did you receive an email confirming the order? There might be a link there to track the delivery.
Otherwise you can submit a ticket via chatbot to customer support here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
There have also been issues with the ticketing system since yesterday, so you might need to send a private message to CS_Agent instead here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
11-04-2022 02:38 PM
Only the CS_Agent can follow up with your order. Have your order number ready so they can look it up but it is up to Canada Post or a courier timeline.
A CS_Agent can be contacted by putting in a ticket through SIMon Chatbot (bottle of page) or private message (envelope icon above) them on this page.
