Need a refund
Marali
Hello, I just purchased a plan with e-sim ,but apparently my phone is not e-sim compatible .
I need either a physical sim card, or a refund.
thank you
hi @Marali what phone do you have? tje not compatible error at thr end sometime is not true
Try to scan the QR code from PM Welcome email and see if it installed
if not, then submit ticket with CS agent here:
@Marali
The cost of an eSIM is free so your refund is $0.
Did you check to see if your phone is eSIM compatible first before sign up?
You can purchase a SIM from a Telus/Koodo store for $10 or from Amazon for $4.99.
Chalupa_Batman
If you already signed up for a plan and have been charged, fastest way to get a physical SIM is to call your local Telus stores to see if they have them available. If they do they are $10 each. You can purchase off of Amazon as well...  Public Mobile SIM   Depending where you are, Kijiji might work too.
DennyCrane
Esims are free for new activations, so you shouldn't have had to pay for it.
Check here for a list of local retailers that may have physical sim cards:
https://www.publicmobile.ca/en/on/get-help/articles/get-a-sim-card
Or buy from Amazon for $4.99:
Public Mobile Prepaid SIM Prepaid Phone - (Universal/SmartPhones), Packaging May Vary https://a.co/d/6aIgwGo
JRod
@Marali
Usually PM is no refunds but you can contact support and they might make an exception. If you want to continue with PM your best bet is to order a SIM off Amazon (https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG/ref=mp_s_a_1_2?crid=2E...) as the ones direct from here can take quite a while to receive.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
