Need QR Code / Some Code for eSim
tmillernl
I am trying to add my PM phone number as the eSim to a work Telus phone I got today.  Says I need a QR code or code that I received from PM.  Anyone run across this yet?
tmillernl
Yes as expected you can't really do anything with Public Mobile.  It does appear the only way to do it right now would be to change my Telus SIM to embedded.
@tmillernl   are you trying to have both Telus and PM number on the same phone?  If so, since PM does not work with eSIM, you will have to make Telus using the eSIM and PM uses the nano SIM slot
hairbag1
Your issue is with Telus, not PM. Give them a call and they're sure to help you out. PM doessn't do eSim or QR.
Triguy
PM does not support E-sim.  I have never heard of QR code from PM.
I think you would need to contact Telus.
