11-12-2018 01:08 PM - edited 01-05-2022 06:06 AM
Can I set up my name to be displayed instead of my number at the receiving end..(without being in their contacts list?)
thanx
Service
01-18-2022 07:04 PM
Did you end up testing by swapping sim cards?
04-15-2020 08:39 PM - edited 04-15-2020 08:45 PM
03-05-2020 12:37 PM
@JenniferM wrote:I have 2 phones on Public Mobile, both using iPhone. with identical plans. The iPhone 5s does not transmit my name, only my number. The iPhone SE transmits my full name. Could the difference be in the settings?
@JenniferM did you port the numbers into Public Mobile from carriers that do/don't store your name? I'm guessing the iPhone SE is using a number that was formerly on a carrier that delivers caller name (e.g. Rogers and subsidiaries, or a landland provider). It's most likely that your name is still in a name lookup database, and that's what's showing up when you call someone.
If you swapped SIM cards between your 5s and SE, you'll find that the name display follows the subscription/line, and not the phone.
03-05-2020 12:34 PM - edited 03-05-2020 01:01 PM
PM will only show your phone number for call display. If the other person you are calling has your name saved in their contacts list then it would display your name.
03-05-2020 12:30 PM
11-12-2018 03:48 PM
While Public Mobile customer receive incoming "Name Display" informatoin, I do not believe that Telus/Public Mobile transmits outgoing information at all. So sorry, there's no option to change your displayed name.
11-12-2018 02:41 PM - edited 11-12-2018 04:25 PM
@kassicho wrote:Can I set up my name to be displayed instead of my number at the receiving end..(without being in their contacts list?)
thanx
PM doesn't have the option to customize this. Not sure what kind of phone you have but this was someone else's solution, might not work for every case, but might work for some phones that use the Internet caller id service whom you call
@hadi wrote:Hello all,
I appreciate the help I got from all your responses. In the end, I got a working solution from the mods. Here's what they said:
@CS_AgentwroteThanks for clarifying
Most phones use third party info from the internet for caller id. After reviewing your account, I saw that you have a Samsung phone. We found the service they use for caller ID.
You can fill out this form to update your caller id here https://hiyahelp.zendesk.com/hc/en-us/requests/new?ticket_form_id=824667
That should fix it! If you need help with anything else, please do let us know.
Hope that helps!
11-12-2018 02:04 PM - edited 11-12-2018 02:05 PM
thanx
As far as I know, only Rogers post-paid customers can customize the outgoing caller name. All other carriers (including PM) only deliver your number.
11-12-2018 01:16 PM
I don't think so.
