My voicemail access number was deleted from my phone... How do I set it up again? What is the number
WSP
8 REPLIES 8
TheSterlinger
Type your phone number and call it.
@WSP   Is the number in the call log in your account?  It would end in 4001.
Meow
Go to settings, call settings, voice mail and enter access number.
For Ontario I have 647-580-4001
Here is complete list; I hope it is still valid:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
HI @WSP
Reset all networks will push the number back
if not, you can reset your call forwarding to default (voicemail) dial ##004#.
or you can manually set one of the VM number here
one number you an use is 778-580-4001
WSP
No phone #mentioned in the faq 😞 already checked, but thanx
WSP
Voicemail number has been bumped from my phone for some reason... I need the phone number to call so I can re-enter it into my phone
Hollister
Phil_Adelphus
@WSP   If you long press the 1 on the dialpad does it not go to voicemail?
