My phone isn’t working
03-20-2023
12:10 AM
03-20-2023
12:14 AM
computergeek541
Account says active but won’t use any data so when out of wifi nothing will go through.
Service
03-20-2023 08:05 AM
@Amyshen - If after you refresh (see screenshot below) your My Account account (or check 611) and you still show data remaining, check if your phone have a data limiter set on it? If so, check the settings and adjust it or turn it off.
Otherwise, what other troubleshooting have you tried?
Try 1 or more of the below:
- restart your phone
- toggle into and out of airplane mode
- perform a Reset of the device's Network Settings
- move your sim card to another phone to see if data works
03-20-2023 06:30 AM
03-20-2023 12:30 AM
Refresh your account page and what does the Usage Data indicate?
You can wait until your renewal top up or purchase additional data Add-on.
03-20-2023 12:14 AM
@Amyshen wrote:Account says active but won’t use any data so when out of wifi nothing will go through.
There's a possibilty that you could be out of data. If you dial 611 and use the option that says something about checking add-on usage, how much data does it say is reamining on your account?
