11-12-2022 04:18 PM
Sorry, your plan does not include sending texts while in the US. Incoming texts are included. To add a US Roaming Add-On, visit selfserve.publicmobile.ca
I can’t make calls I can only call the 611 number but I can’t make any other calls at all. When I try to Call it just disconnects me. I’m connected to T-mobile network And it’s showing service, but I can’t make calls at all because it keeps telling me I’m in the USA please help. When I connect to public mobile Netwerk, it shows SOS in the top right corner and I can’t do anything at all. Not even call 611 when I am on SOS and on the public mobile Network please help
02-23-2023 03:36 PM
yes it works on my daughters phone
11-13-2022 08:15 PM - edited 11-13-2022 08:18 PM
Since you might live right on the USA/Canada border or drive close by, make sure you have Public Mobile as your default carrier. Who knows how far USA carrier signals carry through in the Sumas prairie. What happens if you are in Mission?
11-12-2022 11:56 PM
@BKNS27 wrote:Your will need disable Roaming and change the Network Selection to Public Mobile on your phone.
There is usually no such setting to disabled roaming. The most common setting only disables data while roaming. Either way, the customer has already manually selected the Public Mobile network. Roaming isn't possible after that has been doine.
11-12-2022 08:15 PM
11-12-2022 05:57 PM
@Eesquieres it looks like a general network problem in the area.
Do you have another phone to test and confirm it is not a device problem??
Or test your phone in a other area
11-12-2022 05:50 PM
I switched to 3G and then selected public mobile as network manually, but my phone service went back to SOS again. Its so frustrating
11-12-2022 04:26 PM
@Eesquieres ok, look like you are too close to the border and get the stronger US signal instead
Usually you been to manually select to Public Mobile network. Look like you tried, SOS means something wrong with the network and you are not connected
Try to change your Preferred network to 3G ONLY and then do a manual network connect to PM network again
11-12-2022 04:23 PM
I’m not in the US I’m in Abbotsford, BC
11-12-2022 04:21 PM - edited 11-12-2022 04:22 PM
@Eesquieres to make calls or text in US, you need roaming add-on. Did you get any of the roaming add-ons??
Also, roaming add-ons have 10 days expiry, start counting from the moment the purchase is made successfully
11-12-2022 04:21 PM
@Eesquieres hi you need a US roaming addon while in the US,if you don't have one that would be the reason you have no service
