11-19-2021 02:17 PM - edited 01-04-2022 05:09 AM
11-19-2021 03:26 PM
Just to expand on this a little, most modern devices will work fine with Public Mobile.
There are some devices that will work better than others, depending on frequencies they use. There are types of "locks" that will lock or restrict a device to a particular provider (as well as blacklists that block stolen devices, etc) but in general technology is more accessible these days.
If you're ever in doubt, it never hurts to double check. That's why we're here too! 🙂
11-19-2021 03:06 PM
11-19-2021 03:03 PM
@hank64 wrote:Is the Samsung A70 compatible with this service?
That is an excellent phone for use on PM networks. Just ensure that phone is unlocked from any previous cell network. Also a good idea to ensure it hasn't been blacklisted or reported as stolen somewhere.
https://www.devicecheck.ca/check-status-device-canada/
Welcome aboard.
11-19-2021 03:01 PM
yes. A70 works without issue.. my friend using it on PM
11-19-2021 02:49 PM
Thx. That’s a relief.
11-19-2021 02:18 PM
Yes is will working with Public Mobile.
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
