Compatible? OnePlus 8
tdotdee
Hello! I'm in need of upgrading my phone. I want to buy "OnePlus 8" cellphone, but it's not listed in the compatible phones list (even though its cellular technology says it works with 5G, 4G, 3G, 2G networks).
Could someone please very if it's compatible? I'd greatly appreciate it! 🙂
As long as it supports PM's frequencies, you are good to go!
Of course, ideally, if you can put PM SIM into it before buying it to confirm it works will be the best.
Dunkman
@tdotdee
Yes, it is compatible.
Here are the specs.
https://www.gsmarena.com/oneplus_8-10161.php#
Has the right frequencies for PM network.
@tdotdee
Yes is will working with Public Mobile.
visit Here link to you can check it full information about your device.
Public Mobile uses the following frequency bands:
  • 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
  • HSPA: 850 MHz, 1900 MHz (UMTS).
