03-13-2024 11:38 AM
I got messages from public mobile about every one which used old rewards points have to change to new rewards points in May!I just want to know I took the $13 /month plan will be keep same plan or will be change to another plan?thanks
Rewards
03-13-2024 06:08 PM
i have a question about the loyalty reward please, i have $4 each month,going to reach 5 years in June. .how this is going to work and calculated once the new reward kicked in?(I understand you get $10 after 12 month), does that mean I lost $48 (almost 60 after June) each year?
I am on $15 only, so my new reward is 75 cents plus my $6 referral( i am pretty sure more people leaving , i used to have 12 referals)
03-13-2024 01:27 PM
Don't forget that with the lesser rewards now, you'll feel that price hike even more 👍🤪👍
* cries in first world minimum wage problems *
03-13-2024 01:22 PM
@0utc4st They actually just did a update on the app couple days ago . But still no way to make redeeming points any better . Will they in the future maybe . But I won’t hold my breath im sure we will see another price hike before they start to fix anything if at all
03-13-2024 01:18 PM
It really is absurdly bad.
03-13-2024 12:54 PM
hi @0utc4st not automated, but using the app is not that bad
03-13-2024 12:51 PM
I'm guessing there are no plans to automate this process in the near future or to improve the app to make it easier.
03-13-2024 12:46 PM
@0utc4st Yes now you have the added work of having to wait u til you have 15 points to redeem $15 off you bill now .
03-13-2024 12:45 PM
So does this mean that on top of getting lesser reward value, I'll have to log in every month to redeem my points value?
03-13-2024 11:52 AM
hi @Shirly19 unfortunately the rewards system will change
but plan will be the same
How much rewards you are getting now?? you should have $2 autopay , which will become just 5% points back. You should have have $5 loyalty per renewal , which will become just 10 points once a year
but if you have friends referrals discount, that would stay same but given in points
for the new system, you will have to pay each renewal in full payment first. You redeem for $15 bill credit after you collect and save to 15 points
03-13-2024 11:48 AM - edited 03-13-2024 11:50 AM
your regular plan will continue...it's just your Rewrads will be gone and Points will be your new reward.
added link...
https://www.publicmobile.ca/en/bc/get-help/articles/move-to-public-points
03-13-2024 11:47 AM
@Shirly19 You will keep you plan . But you will lose the $2 auto pay and $5 loyalty rewards .
and it will be replaced with 10 points a year for loyalty and get 5% back on plan spend .
once you have 15 points you can redeem $15 off you bill . This will effectively cost you an extra $50-60 a year . Not good at all
