My eSIM didn't download
MelissaC
I switched from Roger's to PM today and the eSIM didn't download. I tried everything to find the QR ti scan again, nothing. I can't submit a ticket and even though it's during business hours I can't seem to speak to someone. Can someone please help me? I hate to go back to Roger's but I'm out of options without a working phone. And if I go back to them I'll be billed form two companies ies when I don't have this eSIM.
11 REPLIES 11
@MelissaC wrote:
Do you know roughly how long on average for a reply? Can it be like a 24-48hrs ? I'm just not sure, New.
@MelissaC
During Business hours you could receive a response within 30 minutes, during peak times, expect a maximum wait time of 48 hours.
Customer Support Agents are available from:
  • Monday to Sunday: 9AM to 10PM EST
You can check out this section below in your spare time for some helpful information 🙂
Help Articles
MelissaC
Perfect @MelissaC
Check the inbox for support's reply.  They will re-send you the QR code, once installed, it should work.
If any issue after the eSIM profile installed, let us know
MelissaC
I sent a message - pretty sure it went through.
HI @MelissaC
yes, open ticket with Chatbot does not work, but direct message will do.  please message :         https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
MelissaC
OK I'll try that now that I'm in the community. Hopefully works. It's just the eSIM I need. Thank you.
Try again
Right here
  • while your already here and logged in the community
  • you can send a private message   To CS_Agents by clicking >>>>>>>>here.
@MelissaC
use my link to private message and it will work, trust me
MelissaC
I do appreciate the reply but I tried submitting a ticket over 10 times, it says I cannot send a ticket. It's all errors. I can't even speak to an agent during hours online. I'm a bit flustered. If the ticket system worked it would be ok but it doesn't. It's down.
@MelissaC  Message support directly
@MelissaC
Hi, if it didn't download , it is not completed,
There has been some problem with eSIM activation, so please open ticket with them, they can resend you the QR code
Private message CS agent at
