12-23-2022 10:01 PM
12-24-2022 01:54 AM
12-23-2022 10:05 PM
You can try to restart your phone , or network settings
12-23-2022 10:04 PM
Check APN settings:
For android:
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
For iPhone:
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-iphone
12-23-2022 10:04 PM
@CDP23 @Did you add more data on with an add on and do t see it ? If so try and clear your web browser cache / cookies and or try incognito mode / private mode and refresh page and sign in again
12-23-2022 10:04 PM
@CDP23 the My Account page has some cache problem and you might be reading old cached info. Try to login again using Incognito Mode and confirm if you still have data
also, if you are on Android, make sure you didn't have any Mobile Data limit set. Check if you reached the limit and check if the cycle start date on the phone matches the data limit for your PM current cycle
