My data is not working
hetpatel21
Could u please help me my data is not working from past 3 days. I activated my card from past 3 days and it's not working
@hetpatel21 wrote:
I'm using Asus phone . Idk how to do apn setting
Use the link I provided it will give you the steps to verify and change it if required.  It will also let you know if your phone is compatible with the network
Were you with a previous carrier and if so which one?
hetpatel21
hairbag1
What data plan did you subscribe to ? Could you have used up all your data already ?
ShawnC13
What type of phone are you using?  Have you set your APN?
Here is a great site to setup your APN and instructions on how to do it.  Find the APN Settings for Public Mobile here!
 @hetpatel21
What specific make/model phone is it?
Is anything else working?
It's likely APN but let's see what you have to say.
