8 hours ago
a minute ago
Check out this article.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-iphone
6 hours ago
open iphone settings / Cellular / Cellular Data Network / APN should show as sp.mb.com.
7 hours ago
My account is still active, paid automatically. The data is always turn on. I didn't finish my current data as I can't use it. Yes, I restarted my phone, but data still not working. phone calls work.
7 hours ago
@Bayarmaa does your account show as active? Is a payment needed? Did you finish your current data? Did you turn your data off in your phone settings?
Did you restart your phone? Can you make calls??...
7 hours ago
Usually, I have 6GB 4G plan. I have iphone 14
8 hours ago
If you use the PM app, log in to your account to see which plan you subscribed to when you started. See if you have any data for your use. What make / model is your cellphone ?
8 hours ago
in the past I didn't need to use my data. I think it never worked since my subscription with public mobile
8 hours ago
when you log in to your account on a laptop using incognito mode...do you have data available to use.
8 hours ago
yes.
8 hours ago - last edited 8 hours ago
you have data enabled in Settings...right ? Is this something that just started happening or have you had use of your data in the past.
ed
