3 hours ago
I have unlimited text and minutes in Canada and when I want to make a call the message says that I have used up all my minutes and need to purchase more? What is this?
3 hours ago
@JohnLaar wrote:I tried calling a different number and it went through. Now the original number works as well. Thanks for your help.
problem could likely have been a temporary issue with local network in your area. Sounds like you're good to go now.
3 hours ago
Great it is all good without going through PM
and you have taught us a new trick to resolve this problem. Thanks
3 hours ago
3 hours ago
hi @JohnLaar inbound calls and data work?
if calling with 1 does not work and reboot not help either, check My Account to confirm if account is active
then ask PM support agent to refresh the account for you. submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
3 hours ago
if you have another phone, test the sim card there
if not, try reboot once more
and last, ask PM to help
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
3 hours ago
3 hours ago
Tried the 1 and reboot and reset. No change.
3 hours ago
Add 1 in front of the number and see if that works. If not, reboot your phone by powering off then back on.
3 hours ago
common glitch. Usually reboot the phone would be good
or try to call with a 1 in front of the number, or try calling without 1 if you are calling with 1 already
last, try Reset All network after a reboot
