!!!!!! HELP !!!!!
WvuSoldier
I registered for Public Mobile a bit over a week ago. I was given the number (437) 848-****.
I can only make phone calls and use the data plan.
When someone tries to call me, a different person picks up the phone.
I cannot send or receive sms messages.
My phone's IMEI is 35444980086****.
I request urgent resolution of this issue as I am phoneless.
I request my bill be corrected to reflect the error on your network.
As I cannot receive calls or text messages, please email me at ***********@***.***
Respectfully,
Jonathan Nichols
14 REPLIES 14
WvuSoldier
That solution doesn't appear to be an option.
@WvuSoldier  unfortunately it usually takes 2-4 hours for reply from support and they work 8am-10PM EST
@WvuSoldier Tap on "Resend Code". You should then be given the option of receiving it via email. Then pick another number as suggested by @Handy1  In your app, select your account, scroll down to "Change Phone Number" and follow the prompts.
WvuSoldier
Yeah, I sent them a message earlier. No reply yet.
This isn't the best way to start with a new customer. 😕
Thanks for your time.
WvuSoldier
To clarify: I picked the number from PM. I am okay picking a new number. How do I do that?
@WvuSoldier  Get support to help you fix
send  a  private message   To CS_Agent
WvuSoldier
I'm fine to do that. How do I do that?
@WvuSoldier  You picked number from PM correct ? You didn’t port a number ? If you picked number from PM the porting team won’t be able to help . You just need to pick a new number unfortunately
WvuSoldier
I do not:
@WvuSoldier  Do you see option “didn’t get code “ tap it and you may get option to send code by email instead
WvuSoldier
Thank you, I await the private message.
WvuSoldier
I can't login without SMS working. If I had the phone number I wouldn't need to log in.
@WvuSoldier  This happened to me before and I just had to log onto my account and pick a new number it’s glitch . pm sometimes gives number option that belong to somone else
Change # on profile tabs
If you can’t log into bet support to help you
eddieO
@WvuSoldier this is a public forum, ever one on the internet can see these posts so please remove your personal data by clicking on the top right corner of your post and selecting Edit
It sounds like you have a porting issue so I will send you a private message with a number to call
