08-26-2022 01:47 PM
In the Rewards portal, I see the 1 GB redeemed on August 16th.
However, in the Account portal, on the My Account page, I don't see the 1 GB in either the Plan Usage or the Add-On Usage sections. Where and when is it supposed to appear?
08-26-2022 01:59 PM - edited 08-26-2022 02:10 PM
@canislobo19 PM site has been having quiet some issues with caching all the time, it just got worse with the new My Account site now
Glad it is all resolved.
08-26-2022 01:58 PM
That solved it; I cleared my cache and cookies in Microsoft Edge and was able to see the updated numbers.
08-26-2022 01:56 PM - edited 08-26-2022 01:57 PM
I am not familiar with 'redeeming' something to appear on reward portal. All my bonuses and add-ons are on Account portal.
Is that a feature with new Points system?
If you do not see something on any PM portal good practice is to:
Try using different browser. Try Incognito mode. Clear browser’s cache. Try force refresh.
Force-refreshing a page will clear that page's cache, allowing you to see the most recent version of the page as opposed to any information your browser saved in the past: CTRL+F5 or Ctrl+refresh icon (PC).
08-26-2022 01:49 PM
@canislobo19 first , make sure you are not reading off a cached version of the page with old data, use Incognito mode or another browser (Edge/Firefox/Chrome) to login to My Account again.
If you tried Incognito mode and still not see the redeemed add-ons, open ticket with PM Support:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
