2 hours ago - last edited 2 hours ago
added $30 add-on for 3 gig data, it says it is there and they took the money. it says i am using the data but i don't have the internet. How do I get it working it has been over 30 hours
2 hours ago
I really appreciate this. i will get my daughter to try. we have been at wits end.
2 hours ago
Thank you! I will do this. I really appreciate it. My daughter is using the phone and it very frustrated.
2 hours ago
hi @Jenny-10
first try to reboot the phone
and check My Account again. to avoid browser cache problem, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
@Jenny-10 Maybe try to reboot the phone see if that helps . If still same issue . But maybe you got the U.S. roaming add on by accident . Double check if so ask support reverse it
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send direct private message to support .
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
