My account
KNC1
 Just opened acct. Waiting for sim to activate. Once that's done when do I change my cell number. Just moved to ab from ont
Exactly what @dust2dust said.
However if you're looking for a really good number that's easy to remember or what have you, I went to both TextNow and Fongo and played around till I got a number I really liked. After a week of being on PM, I ported the number here. It's a bit of work but to me it was worth getting the number I got.
If you aren't bringing your old number to here then just pick a new number. Otherwise, when you get the sim and use the app to finish the sign up then you bring in your old number. Or pick a new number. Or pick a random number and make sure your service is all good and then bring in your old number.
KNC1
So I can request a new cell # during activation?
