03-09-2023 02:02 PM - last edited on 03-09-2023 02:46 PM by computergeek541
I logged in and it says my account is active so I don't understand why I can't make calls. I have already done the basic troubleshooting steps that usually fix and issue such as this.
03-09-2023 02:34 PM
Thank you for your help, I will submit a ticket!
03-09-2023 02:30 PM
Thank you for your help!
I'll go ahead and submit a ticket because I've done everything listed above. 🙂
03-09-2023 02:13 PM
There has been a calling bug that has been around a couple of time this past week. Maybe it is making another appearance here. @brooklynjogrady , if you did not activate recently and phone reboot is not fixing the problem, you are probably experiencing the calling bug. Initiate a support ticket to resolve this problem.
03-09-2023 02:12 PM
HI @BKNS27 OP can not make calls, I would assume it means outbound calls, then it's not porting related.
03-09-2023 02:09 PM
There could be 2 reasons:
1- If you just ported your number over to PM, did you confirm to the text with YES you are porting over to PM with the old SIM in your phone? You have 90 minutes to confirm or porting will be in limbo.
2- If you are an old member, it could be a backend issue with the SIM.
In both cases you need to contact a CS_Agent by submitting a ticket on SIMon Chatbot on the bottom of this page or private message on the envelope icon above.
03-09-2023 02:06 PM
can you receive calls?
Reboot the phone first
or try your sim card in another phone
PM had some voice problem earlier, but I am sure it is now all fixed. But if you like , submit a ticket wtih CS agent:
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
